Stroker Crank for 88
Rod
08-17-2004 08:21:02
Looking for; Stroker Crank for Oliver 88, S88 or 880, let me know what you have. AND/OR original crankshaft from S88, 880. Also engine block from S88/880.
I think you guys know what I am up to... any advise? Not looking for huge 88 just a good solid bottom end.
Any good combinations?
Rich
08-18-2004 13:41:54
 Re: Stroker Crank for 88 in reply to Rod, 08-17-2004 08:21:02
my 88 is stroked out to 5.250 no problem with turning 2500 rpm,have another stroked to 6.125 only turn about 2150 on that one.I think you have the right idea about the 5" stroke thats a good one. A 4x5 is 377 good engine too. Rich
Puller
08-18-2004 05:19:43
How about a 99 crank? 2-5/8 rod journals.
Rod
08-18-2004 05:36:35
 Re: Stroker Crank for 88 in reply to Puller, 08-18-2004 05:19:43
Interested... email me please.
wags
08-17-2004 14:06:46
At those rpms you will need a lot of cubes to get good horsepower. you can try 5" but if your spending the money on stroking might as well go as far out as you can, the rods and pistons will cost about the same regardless, once they have to start grinding the cam and block to fit the stroke
then it gets spendy.
Rod
08-17-2004 10:46:14
I would like to be able to run DIV III, NATPA but able to hit local pulls, some brush pulls where they allow some RPM... nothing over 2500 RPM.
I had it in my mind not to go over 5" in stroke.
mitch
08-17-2004 10:02:50
Depends what class, high rpms or big cubes or combination of both, what do you want?
