M governor again
hayfarmer
08-17-2004 07:51:08
I asked about stiffer springs for a governor on a SMTA. Was given 2 numbers, one a JD number and the other 166.167. Not sure what kind of numbr that is or how to go about finding the spring. Any help would be appreciated.
hot M
08-18-2004 10:49:45
 Re: M governor again in reply to hayfarmer, 08-17-2004 07:51:08
you can go to the NAPA parts store and get a spring that will do any thing you want it to do.
SMTA PULLER
08-17-2004 11:12:11
D o it hardware store no166 is idendical to specs posted sometime back for notorious magic spring.I paid 92 cents for one. Wiyh mand w4 weight gov. my SMTA will turn 2000 easy.No 167 is one more coil the extra length makes it idle down alittle better.Paid 97 cents for it otherwise performance is similar.
Hayfarmer
08-17-2004 13:19:17
 Re: M governor again in reply to SMTA PULLER, 08-17-2004 11:12:11
I am looking for spring for a SMTA but sure is same as M. I don"t pull but do use it on pto baler and pulling disc and plow. Not sure I am familiar with do it hardware, Is that a midwest or eastern firm? I live in Washington State. Is there a place I could order a spring on internet that you know of?
Thanks for the response
