Nitrous use with new diesel tractors?.
Jonathan
08-16-2004 06:08:27
Hello, someone told me, and I don't really believe them that some of the best pullers of the new tractors use nitrous syestems. They hide the tank somewhere on the tractor out of sight and activate the syestem by wiring it up to the windshield wiper controls or such. I wouldn't think nitrous would work for pulling because the tractors run out of power frequently, and stall the engine, which I would think would be deadly to the engine if you still had some nitrous in the cylinders and had stalled it. I wasn't aware that nitrous could be used with a diesel?.
buickanddeere
08-16-2004 14:01:14
 Re: Nitrous use with new diesel tractors?. in reply to Jonathan, 08-16-2004 06:08:27
Why would nitrous damage the engine. It's just an oxidizer. As it N02 turns from liquid to vapour it drops to about -126F making the intake charge cooler and denser. As well as containing up to about 33% ozygen and 66% nitogen buffer. It's easy to add fuel with a diesel but pumping the extra airflow to burn the fuel is the trick. The cold nitrous mixture helps limit combustion chamber and exhaust stack temps too.
Redman
08-16-2004 18:14:38
 Re: Nitrous use with new diesel tractors?. in reply to buickanddeere, 08-16-2004 14:01:14
it is dry,no lube.
stall the engine and you better plan on puting in a couple of pistons.
buickanddeere
08-16-2004 20:15:26
 Re: Nitrous use with new diesel tractors?. in reply to Redman, 08-16-2004 18:14:38
There should be lots of fuel oil lubrication from an overfueled engine. Maybe some people are running more nitrous than required and are running lean/hot causing scored/melted pistons? Stalling gives the piston/sleeve time to boil the lube oil out before movement starts again. Piston & sleeve cooling would be interupted during a stall as well.
Redman
08-17-2004 11:12:22
 Re: Nitrous use with new diesel tractors?. in reply to buickanddeere, 08-16-2004 20:15:26
we have used alcohol with the diesels,the problem is always when you stall them or just pull them down too far you end up with a engine failure.
a friend of mine used the nitrous on his and it was about the same deal,the heat is just too much when added to diesel.
it does add power,but it is risky to say the least.
buickanddeere
08-17-2004 19:37:04
 Re: Nitrous use with new diesel tractors?. in reply to Redman, 08-17-2004 11:12:22
One has to be careful with too much alcohol. Alcohol is a solvent that disolves oil in an instant. There goes the lubrication from the diesel and crankcase oil that was keeping the pistons and cylinder walls from galling together. These piston failures at low rpm and after stalling point to localized overheating and failure/buring off of the lubrication.
G-MAN
08-17-2004 13:47:17
That type of failure would be due to leaning the engine out too much. The extra oxygen in nitrous demands extra fuel. Once it has consumed all the available fuel, it goes after other combustibles, such as aluminum pistons. If you dump nitrous in any engine without adding more fuel, it's going to fail.
Redman
08-18-2004 10:14:19
 Re: Nitrous use with new diesel tractors?. in reply to G-MAN, 08-17-2004 13:47:17
it was getting plenty of fuel,around 800 ccs with 1 turbo.
problem is when a diesel chokes the cyl temp is already very hot and the alcohol or nitrous adds more heat.
i"m not saying it can not be done,but it is some expensive schooling.
G-MAN
08-18-2004 11:12:56
 Re: Nitrous use with new diesel tractors?. in reply to Redman, 08-18-2004 10:14:19
Nitrous oxide is not a fuel and will not burn independently. It adds oxygen and allows you to burn more fuel and make more power. But, if something such as a piston crown is already hot enough to burn - aluminum can burn - the nitrous will feed that fire and start burning away the piston. That's where you get the extra heat you speak of. Alchohol is a fuel and can burn, but it's a completely different situation than nitrous. I agree with buickanddeere that alchohol-related problems are due to a break down of lube in the cylinder. Although I'm sure the end effect is the same - a ruined engine. The main problem to overcome when using it in a diesel would be closely regulating it so you didn't lean out, as diesels only take in air and then inject the fuel later. Gas engines are bringing in air, fuel and nitrous all at once, so it's easier to regulate the burn. I'm not sure, but I think there are commercially available nitrous kits for diesel pickups already out there.
LW
08-17-2004 15:56:35
That's exactly right the troulbe is most guys start out with a jet size that is recomended with out basis and don't tune the nitrous system, I know with gas you can regulate bottle temp.and press. also the fuel pressure flowing through the actuall fuel jet and read all the "signs" plugs,exhaust temp etc. and make unreall improvements without touching the jets.
CASEPOWER
08-16-2004 09:14:39
Yes, it is being used. Know it for a fact!!
AO
08-16-2004 07:56:26
Check out bullydog.com for info! A diesel is a natural for NOX
