elercitronic ingtion
Farmall Puller
08-13-2004 17:46:13
How much power does a elercitronic ingtion give a farmall H????? ????? ///
buickanddeere
08-14-2004 22:13:27
 Re: elercitronic ingtion in reply to Farmall Puller, 08-13-2004 17:46:13
The electronic ignition adds ZERO HP. It just helps ensure the engine puts out it"s max possible HP.
Jason(PA)
08-14-2004 19:00:33
Buy it you won't regret it. I noticed alot better throttle response and starting. Its easy to put in and worth not having to deal with points ever again.
770
08-14-2004 14:18:08
How about it keeps your plugs cleaner. It will fire down to zero rpm. You won't have to change points or clean them..... easier starts...Sold???
TheRealRon
08-14-2004 09:18:19
It depends.
If you mean a points replacement type then the answer is zero.
If you mean a GM HEI type with 50KV coil and platinum plugs with .055" gap, then the answer is 5% to 10%.
Buzzman72
08-14-2004 07:20:33
 Re: electronic ignition in reply to Farmall Puller, 08-13-2004 17:46:13
Now, since I'm not a puller--yet--I'm not giving an expert's opinion here. But let me say that, assuming that an electronic ignition will give a more consistent spark...both in duration and intensity...than a points/condenser setup, the difference should be quantifiable on a dyno. It may be only 1/2 a HP, it may be 3 HP...and it may vary by rpm and load. But the ignition should be optimized by using a coil that can live up to the potential of the electronics, rather than being a limiting factor.
That's all theoretical, of course, but it's based upon sound internal combustion engine science. The degree it affects YOUR engine will depend upon the mechanical condition of the engine, i.e., how well the rings seal and what kind of cylinder pressures are generated by your engine.
So if somebody tells you it's worth, say, 5 HP, it just might be on HIS engine...but YOU may only see, for example, 3 HP on YOUR engine, based upon its condition and settings.
Dave S
08-14-2004 03:13:27
Farmall Puller, I don't know about power gains but our two DC's start quicker and run smoother with the Pertronix Ignitors and hot coils. The only draw back is we had one go to heck at a pull and we were done for the day. I don't keep any around at $69.00 a pop. Dave S
DickTN
08-13-2004 23:44:04
If you can't even manage to spell "electronic", you probably shouldn't even BE on a tractor.
farmall puller
08-14-2004 06:15:36
 Re: elercitronic ingtion in reply to DickTN, 08-13-2004 23:44:04
Hey DickTN Im a 12 year old kid Geez
Flogger
08-14-2004 10:45:08
 Re: elercitronic ingtion in reply to farmall puller, 08-14-2004 06:15:36
Go with the electronic ignition and a hotter coil, you won't be sorry... and stay in school, lol.
Hayfarmer
08-13-2004 21:54:17
Last time I got points and condensor for my SMTA it ran around $20. Doesn"t take too long to justify the electronic ignition.
DCTOM
08-13-2004 18:48:29
cant say it makes any more hp my case just runs better and i dont change points twice a year
champspa
08-13-2004 17:57:50
it doesn't give it any it just let's you enrich your carb and still burn it. just my opinion let's see what everone else thinks . let's hear it Chad
MOFarmallHPuller
08-15-2004 06:41:21
 Re: elercitronic ingtion in reply to champspa, 08-13-2004 17:57:50
Hey champspa if you get to "enrich" your carb your putting more fuel in the cylinder thus making more POWER
