JD 520 Pistons in a JD50?
JDMark
08-13-2004 16:10:14
Hi, I have a JD 50 which I want more power I was told that if I use 520 pistons it will raise my compression is this true? Are the wrist pins the same as my 50? Thanks Mark
BushogPapa
08-15-2004 21:19:31
 Re: JD 520 Pistons in a JD50? in reply to JDMark, 08-13-2004 16:10:14
Which ever you use, stay below 8:1 compression for a farm work oriented tractor... A Power Block would be your best bet for a real good power increase.. I know of one JD "B" with a power block that regularly pulls a 3-14" pull type plow... I don"t see any reason you can"t get into the 35 to 40 HP range..
JDMark
08-14-2004 05:49:10
If I use the 520 pistons in the 50 will they clear the sparkplugs since the 520 has them in the head and the 50 has them in the clyinders? Would it increse the compression much or would I be better of to just mill the head and cylinder down. I have had the cam reground by roberts and it helped a lot. Mark
Gogar Fla
08-13-2004 17:20:01
I have been told to make one really pull is to use a 520 camshaft. In the letter series we use lp pistons.Good luck
buickanddeere
08-13-2004 19:52:17
 Re: JD 520 Pistons in a JD50? in reply to Gogar Fla, 08-13-2004 17:20:01
The B,50,520 & 530 all used identical cam timing and lift.
WTW
08-16-2004 10:23:40
 Re: JD 520 Pistons in a JD50? in reply to buickanddeere , 08-13-2004 19:52:17
Correction, A late "B" uses the same cam spec. as the later model tractors you mentioned, early "B's" (1935-1946) are different specification. DW
buickanddeere
08-16-2004 20:18:29
 Re: JD 520 Pistons in a JD50? in reply to WTW, 08-16-2004 10:23:40
True but the factory replacement B cam right back to 1934 used the late B/50/520/530 specs.
