H farmall pistons
Big Dave
08-12-2004 09:37:12
Is there a piston that fits the H block without sleeves? I heard that the piston could be used by removing the sleeve and not have to bore.
RED WHEELS
08-12-2004 21:51:15
 Re: H farmall pistons in reply to Big Dave, 08-12-2004 09:37:12
Don't waste time with 3 9/16 when you could bore it slightly and install 3 5/8 pistons from the farmall 350.
ChadS
08-13-2004 08:26:12
 Re: H farmall pistons in reply to RED WHEELS, 08-12-2004 21:51:15
Yeah, for less than 500 dollars you can get the whole 350 sleeve and piston engine kit. 3-5/8 bore, just change the wrist pin size. ChadS
ken b
08-12-2004 12:40:01
A 460 Piston will fit. But it will not come all the way to the top. It likes about 1/8 to 1/16 . But I still have about 125 compression. also the rod pin is larger . Ken
JB
08-12-2004 09:45:17
460 pistons I think. See what others say. 3 9/16 inch.
Don
08-12-2004 10:46:42
 Re: H farmall pistons in reply to JB, 08-12-2004 09:45:17
when i did my motor this winter i took the sleeves out of the block and the new pistons fit in b4 i bored the block and put the new sleeves in and the new pistons are 3 9/16
