m govenor
joe
08-11-2004 15:43:01
how does putting a stiffer spring in the govenor increase rpms i think that it would do the opposite the stiffer spring the hard it would be to open
cluttering up
08-13-2004 11:02:02
 Re: m govenor in reply to joe, 08-11-2004 15:43:01
Chad S has springs that do a good job
RoyG
08-11-2004 19:37:01
The spring opens the carb and the weights on the gov pull against the spring to close it and hold it at governed speed. When the speed slows down the spring will pull it back open to speed up.
Hayfarmer
08-12-2004 08:15:08
 Re: m govenor in reply to RoyG, 08-11-2004 19:37:01
Where is a good place to get a stiffer spring for the M, Super M family? Someone here said a H-350 spring was stiffer. Have seen these advertised but 40+$ seems a bit high for a spring.
do it hardware store
08-13-2004 11:07:27
 Re: m govenor in reply to Hayfarmer, 08-12-2004 08:15:08
GET part no. 166.167 is the same only one more coil about a buck each.A JD part a50041 isalmost identical performancewise 2bucks list.2000 rpm is easy.
sorry
08-13-2004 13:18:42
 Re: m govenor in reply to do it hardware store , 08-13-2004 11:07:27
The correct John Deere no. is a50047.
