JD 9-Bolt Wheel Adapters
Eric
08-11-2004 06:43:02
Is anyone out there making adapter plates, used on the John Deere A's, B's, and G's, that bolts to the stock cast wheel hub and has the 9-bolt pattern drilled in it? If not, does anyone have the cast wheel hub bolt patterns? I have been told that 3 holes use one bolt circle while the other 3 use another but they never know what sizes. I am particularly interested in the A and G sizes but someone else might what the B info.
Hell, if I get some good info, I will draw them up on the computer and post the drawings for all to use. Maybe even try this for other brands. I know of a Ford in our club using adapter plates. Something to think about. Thanks.
Gpower
08-11-2004 07:42:03
 Re: JD 9-Bolt Wheel Adapters in reply to Eric, 08-11-2004 06:43:02
I have a set that are cut out of the solid cast centers, like off the GM, where there was not a seperate center, but all one peice, plus the collar. They are machined down so that a 9 bolt wheel will fit right on. No welding or modifing needed, and they will fit on any G axle. They are a little heavy, but easy to use. I have access to more if interested.
Mike M
08-12-2004 03:20:14
 Re: JD 9-Bolt Wheel Adapters in reply to Gpower, 08-11-2004 07:42:03
I would also be interested in a set for my 47 G Please let me know
Gpower
08-12-2004 04:50:15
 Re: JD 9-Bolt Wheel Adapters in reply to Mike M, 08-12-2004 03:20:14
Send me an e-mail.
[email protected]
Thanks
Eric
08-11-2004 08:28:28
Thanks for the offer but I am looking for the plates and particularly interested in the dimensions used to make the plates. I want to draw them up and post them in the "parts and pieces" section for all to use. Info on other models is welcome.
mike k
08-15-2004 16:00:34
 Re: JD 9-Bolt Wheel Adapters in reply to Eric, 08-11-2004 08:28:28
I have a set of adaptors to do what you want to do. e-mail me if interested, mike
Jason Crots
09-08-2004 17:07:08
 Re: JD 9-Bolt Wheel Adapters in reply to mike k, 08-15-2004 16:00:34
Would be interested in wheel adapters for 50 JDG Thanks Lynn
ChadS
08-11-2004 07:36:04
I dont make them, but I have a set of plates that bolt on ot the cast center hubs, to convert them from cast wheels to pressed steel, they are off an A. 1/2 thick, dont know if they will fit any other model than the A. Email me if you want them. Chad
Cody
08-12-2004 19:47:33
 Re: JD 9-Bolt Wheel Adapters in reply to ChadS, 08-11-2004 07:36:04
call Tony Smithson @ 615-794-8979. after 8 pm. cst. He makes them for WC's and I think they are the same bolt pattern as the deeres. They are billit aluminum. $185 a pair.
