copper head gasket re-torque?
Shutt30
08-10-2004 19:31:59
When useing a copper head gasket do you re-torque the head when a sealent is used?
BushogPapa
08-11-2004 06:30:56
 Re: copper head gasket re-torque? in reply to Shutt30, 08-10-2004 19:31:59
Since you put the head on Cold, the actual head torque at RUNNING Temprature will be Less, as everything expands, even the head bolts and studs. I would guess that you are using a copper head gasket because you want to work it good and hard.. Get it up to a FULL Operating Temp ( not just warmed-up )....like work it about an hour..then re-torque it.. I'll bet you will see the bolts tighten more.. You will have to re-adjust the valves anyway...why not re-torque at the same time..?? Ron.
