Missouri State Fair Antique Tractor Pull- an updat
Mike Aylward
08-09-2004 17:13:27
Last week I posted here mentioning that there might be a change in the pulling order at the Missouri State Fair pull on August 18. To clear up some rumors this is what will be taking place. Normally, the break is taken after the 5000 styled antique class has pulled. This year, in order to keep the large 5500 and 6500 styled antique classes from pulling at the same time, we are going to pull the 5000 styled class in the evening, and the 5500 styled class will pull in the morning. Only these two classes will be changed. All other classes and approximate pulling times will be as before. All the other classes pulled without problems before and only the 5500 and 6500 styled classes were in need of separating. Hopefully this will eliminate that confusion without affecting all other pullers. Spread the word around about this change. We look forward to seeing all of you at the fair this year. It is looking like an even bigger pull than last year at this time. Mike
Jerry
08-10-2004 07:17:44
 Re: Missouri State Fair Antique Tractor Pull- an u in reply to Mike Aylward, 08-09-2004 17:13:27
How much bigger do you think that the pull is at this point Mike?? Also, what was the final # of hooks for last year??
Mike Aylward
08-10-2004 13:27:35
 Re: Missouri State Fair Antique Tractor Pull- an u in reply to Jerry, 08-10-2004 07:17:44
Jerry, we had approximately 420 hooks last year and this year looks to be bigger. We have already received about 40 more pre-entries than last year. We are going to be busy that day.:-) Mike
