wheely bars for farmall M
Jon in OHIO
08-08-2004 10:54:12
wanting to make some wheely bars for my M .my M has the stock 13.6 rims and tires.how long should they be. what angle.any help would be great .thanks
Ohio M Puller
08-10-2004 09:05:40
 Re: wheely bars for farmall M in reply to Jon in OHIO, 08-08-2004 10:54:12
John,
The way we make ours are real simple, cut a piece of 2" square tubing 12" which will be on the front of your axle. Next, cut a piece of 2" square tubing 18" long this will be the piece that will be on the back of your axle housing. Then cut a piece another 2" square tubing 13" with 45 degree on one end this will be your bottom support that will be vertical with the ground. Next cut a piece of 2.5" square tubing 24" long with a 45 degree at one end, this will be the piece that will run downward towards the ground on an angle. Lastly, Cut another 2" square tubing 20" long with a 45 degree angle on the one end, weld on a piece a flat plat of 3/16 steel as your ground pad. We use 3/4" hardned all tread for the top and bottom of the axles to attach the 12" and 18" pieces. If I have lost you I understand. If you have any more questions call me 419 295 4592 Adam Coleman.
Ohio M Puller
