460-560 Exhaust Manifold
FarmallHO
08-08-2004 10:29:44
Is there anyone making a tubular exhaust header for the six cylinder Farmalls? The stock one doesn't look like it would be very well tuned? Thanks
Team Hardscratch
08-08-2004 22:15:07
 Re: 460-560 Exhaust Manifold in reply to FarmallHO, 08-08-2004 10:29:44
We run a 560 gas with a 301 engine. We have made both intake and exhaust manifolds for the tractor. It has really helped to increase the flow. Have tried several designes and finally came up with on we liked out of stainless steel tube. Don"t know what you are thinking of running but we are around 6500 rpm going down the track with a demon carb and turbo charger. We did run the stock manifold for a long time at about 5200 rpm and had no problems with it. We just wanted to increase the flow so changed. I don"t know of anyone making them to sell but most machine shops if given time can prob. make one for you. or if you are handy with a welder could make one yourself. The exhaust is the easy one the intake design was alittle more difficult. we have a triangle design with a screen inside to help distribute the fuel more evenly so you don"t just dump into the middle cylinders. We tried multiple designs and this is working the best. Sorry so long.
T-Rex
08-08-2004 17:55:50
Don't know what your building, but we have a 560 with that manifold, pushing well over 100HP. CM
