ChadS.
Brian
08-06-2004 20:42:25
Chad I am having problems with head gasket sealing on my H. Tried E-mailing you but I don't think its going through. Is there any way I could get your phone Number, I would like to talk to you in person.
ChadS
08-06-2004 20:56:18
 Re: ChadS. in reply to Brian, 08-06-2004 20:42:25
What bore, and where is it leaking? Chad
Brian
08-09-2004 18:24:10
 Re: ChadS. in reply to ChadS, 08-06-2004 20:56:18
The block is not leaking, its the squared combustion chambers on the head. The fire ring is on the inside of the edges of the chambers, ring is not being crushed in these areas. Back corners next to the valves.
ChadS
08-11-2004 07:42:24
 Re: ChadS. in reply to Brian, 08-09-2004 18:24:10
Is it overbored? the firering is hanging over the cyl as well? There is a larger, stock gasket that will hold up to a 3-13/16 bore, it has a larger cyl fire ring diameter, the head set is off of a C-175 engine, (late 350-and industial engines) I got mine through napa,,, should seal ya up if that is the case. if not, I have copper gaskets,, is it still sleeved? Chad
Wally G.
08-07-2004 15:28:06
Hey ChadS, is there a better head gasket out there for a 460D?
buickanddeere...70 carb j
08-07-2004 07:27:51
Chad Carb jetting info down few posts with G-Man's question. Seems to be some larger jets depending on displacememt, HP and fuel type. My home e-mail is messed up. I can recieve sometimes if it doesn't crash on low memory. Can't send at all after installing some super duper Norton antivirus software.
