4430 boost
Bill R
08-05-2004 18:43:38
How much boost should a 4430 make? Can I change the sleeves in my 404 and make it a 466 easily?
WTW
08-06-2004 07:29:52
 Re: 4430 boost in reply to Bill R, 08-05-2004 18:43:38
Bill, A stock 4430 will run between 12 and 15 pounds of boost. With a different turbo and fuel setting it is easy to get 60 pounds. A 404 block can be altered to take a 466 sleeve but you will have a poor quality block because of casting design differences. The late 404 engine as used in the 4430 can have a 466 block swapped in it with no real big changes other than block, sleeves and pistons. If you are interested I have a block, sleeves and pistons (used). that I would sell both for $750.00. Email me if interested. DW
