Where can I buy Pressed Steel Wheels
Hank MO
08-05-2004 04:13:40
I hear a lot of talk about replacing cast rear centers and rims with pressed steel wheels to help shed a few pounds. Where can these be purchased, what sizes are available, what hubs will they fit?
Thanks.
Ohio M Puller
08-06-2004 04:43:56
 Re: Where can I buy Pressed Steel Wheels in reply to Hank MO, 08-05-2004 04:13:40
If you need the hubs I have a set of Oliver 88 that will fit on a Farmall M-450 if you need. Call me 419 295 4592
Ohio M Puller
mark b.
08-06-2004 04:27:16
i have some press steel ready to go what size do you need.
Pete1468
08-05-2004 15:33:19
What size do you need, and what tractor are you going to put them on? I've got some 9 bolt hubs that are used and a set of 18.4x38 9 bolt rims that I'd be will to part with fairly cheap.
mark b
08-06-2004 11:55:38
 Re: Where can I buy Pressed Steel Wheels in reply to Pete1468, 08-05-2004 15:33:19
where are you located and how cheap.
Pete1468
08-06-2004 13:53:07
 Re: Where can I buy Pressed Steel Wheels in reply to mark b, 08-06-2004 11:55:38
I live in northwest Iowa north of Sioux City. I'd take $100 for the rims with a set of BF Goodrich tires on them that would work for duals.
Mopower
08-05-2004 11:19:49
Try to search the web for Miller Tire of Ohio. They sell everything and travel around to pulls and shows.
