how light can you get an oliver 1855
hartparr2844
08-02-2004 13:30:36
just wanted to know if anyones seen an 1855 pullin light classes say 6500 that is an actual 1855 thanks
ol George
08-03-2004 18:58:06
 Re: how light can you get an oliver 1855 in reply to hartparr2844, 08-02-2004 13:30:36
I have done a little bit of work on these. I had a 2255 in the 6500 modified farm. I think it is very doable, just depends on what the local rules say you have to have on the tractor, or more importantly what they don't say you can't take off.
eric lockstein
08-02-2004 19:01:22
would you have any enough on (how light) for a 1850 diesel and the best performance kit for it?
thanks for your time
eric
David
08-02-2004 17:20:54
There was a guy that use to pull around us with an 1850 gas in the 6000 lb. class. Don't know what all he did to it, but it had a narrow front and pressed steel on back.
North of 8 Rebel
08-02-2004 17:13:03
Seen a 1850 at 7000 with some room to cut more yet. But 1855 rear end is a lot heavier than the 1850.
Redman
08-02-2004 16:48:05
it can be done,if you want to go through all the work to do it!
i have seen a 2150? the one with the 3208 cat in it down to 7500.
North of 8 Rebel
08-02-2004 17:10:23
 Re: how light can you get an oliver 1855 in reply to Redman, 08-02-2004 16:48:05
2255 had the cat in it, 2150 had the hercules inline six.
Redman
08-02-2004 19:25:44
 Re: how light can you get an oliver 1855 in reply to North of 8 Rebel, 08-02-2004 17:10:23
i stand corrected!
i knew their was a 2 and a 5 in the number.
