First time puller builder
kyle
07-31-2004 16:32:15
Found a massey 44 dead stock runs great i want to make it into a puller for very low $$ just something for antique class and pointers would be great!!
marlowe
08-01-2004 17:53:05
 Re: First time puller builder in reply to kyle , 07-31-2004 16:32:15
get a good [[[[OLD]]]] set of firestone 23 field and road dry and hard 14.9 or 15.5 get the tractor down to 5000 and 6000 use wheel wts. at 5 and add 500lbs more wheel wts. for 6 and then use the other 500lbs. as placenent wt. and go pull and you will kick a$$ pull in 1st gear. if you can make some real small front tires to get the front down little 12in. work good. i pull a 44 and have a wall full of plastic dust collectors did not do a thing to the engine and can pull with the best of them. work on the balance and draw bar lenght
