Creeper Gear for a JD70
Green Gaint
07-29-2004 13:29:19
I was wondering if any of youguys know how to slow down a 70. Thinking of pulling one heavy but goes to fast and runs out of power anybody know how two slow one down? Any help is appreciated. Thank you
ChadS
07-30-2004 22:17:52
 Re: Creeper Gear for a JD70 in reply to Green Gaint, 07-29-2004 13:29:19
What size tires are you running?
Dale
07-29-2004 22:14:14
I don't know it for a fact, but I've heard that if you get thepulley gear and first reduction gear from a 70 diesel, that will reduce your ground speed.
John
07-30-2004 19:39:59
 Re: Creeper Gear for a JD70 in reply to Dale, 07-29-2004 22:14:14
That is correct although if you have Live PTO you will have to bevel the inside of the pulley gear to gain enough clearance to get the pulley to run where it is supposed to, you will lose some ground speed but not a great deal though I'm guessing you might go from 2-1/3 mph to 2 mph and also you will have to remove the oil slinger gear in the bottom of the reduction cover
720Deere
07-31-2004 05:05:28
 Re: Creeper Gear for a JD70 in reply to John, 07-30-2004 19:39:59
Sounds like an awful lot of work! Much easier to just buy a 720/730 to pull with. I love the 70s, but I wouldn't have one for pulling. To pull light enough to accomodate that high gearing, you can't balance them very well.
