SparkPlug J.D. G
Phil K.
07-26-2004 19:08:48
Hello everyone, im enjoying reading all the info everyone is providing. my question this time is, does anyone notice any difference if they run a D23 spark plug rather than a stock D21 spark plug in their john deere g? or even any other tractor. thanks if anyone has input on this.
Phil K.
07-31-2004 06:44:26
 Re: SparkPlug J.D. G in reply to Phil K., 07-26-2004 19:08:48
Thanks guys, looks like im gonna be going to parts store to pick up some diferent types of plugs to try. i'll probibly try the 3116 first at the Memphis, Mi pull sunday. thanks guys!
Pullin A
07-29-2004 19:30:57
I think it is funny reading everyones replies because I have had the total opposite luck with champion. I would not use Auto 3116 if they were free, put them in my stock A to plow snow and I could not even finish the first time I plowed. Went to the Ac c86 and they lasted two times, about abn hour each. Went back to the d-23 that I normally use and have not changed them since and I have over 50 hours on these plugs.. Did not change a thing except adding more gas. I have now use them in a stroker A and am still on the same set for the entire pulling season. Just my experience, good luck with finding what works in your tractor.
big jugs
07-27-2004 20:59:06
Toss the Champion plugs and quit buying stock in their company. I asked for other recommendations last winter and it was suggested to try Autolite 3116. Put them in in March, and am still running the same two plugs!. Just my opinion, but I feel Champion is at the bottom of the barrel.
JDGnut
07-27-2004 12:54:17
I have switch all most all of my tractors over to the small plugs... I won't use the Champion plugs.. they seem to just be die... for the big plugs I use the 386's and 388's... JDGnut
Mike S
07-27-2004 11:39:33
I have good luck with autolite 3116
Dale
07-27-2004 08:14:44
I quit running Champion plugs when I started pulling my "G". I prefer the AC C87, which is the replacement for the C86. Good luck and good pulling.
Stroker G
07-26-2004 19:53:24
Hey Phil, I never good luck with the D21 plugs. I've always used the AC C82 or C86. I run the 82 in the Stroker and the 86 in the stock tractor. They seem to last the longest for me anyway. Hope it helps.
c86
07-26-2004 20:15:15
 Re: Re: SparkPlug J.D. G in reply to Stroker G, 07-26-2004 19:53:24
I have had excellent luck with the C86. The only problem is the C86 has been discontinued and replaced with the C87, and the C87 won't work in my tractors...the threads are fine but the space between the threads and the part the socket or wrench grabs to loosen/tighten is about half that of the c86's and the part the socket/wrench grabs goes down into the hole for the spark plug and you can't get it completely tight. If you do get it tight you can't get it loose. I hope all that made sense.
steve
07-27-2004 09:07:15
 Re: Re: Re: SparkPlug J.D. G in reply to c86, 07-26-2004 20:15:15
y do you recamend c86 and are they the same as w18
Carl
07-27-2004 16:25:20
 Re: Re: Re: Re: SparkPlug J.D. G in reply to steve, 07-27-2004 09:07:15
Tried them all ( AC, Champion, Autolite ) have had the best luck with DENSO plugs.
