Super 88 diesel on dyno
Lynn
07-25-2004 08:53:20
We have a new $20,000 dyno at work that shows RPM, horsepower, and torque. Super 88 has 1/2 inch of stroke, and 4-1/4 bore. It comes out to 383 cu. in.
I am only getting 70 hp at 540 rated, but am getting 686 ft. lb. of torque. It felt like the pto shaft was going to break at any time.
I have messed with the timing and the torque screw on the roosa master pump. Would it help if I drilled out the precombustion chambers to the next drill bit size bigger? I think that it would let more fuel into the chambers, I have heard of other people doing this and it gained more torque. Does anybody know what the stock torque reading was from the nebraska tests is? I know what the stock horsepower is, but torque is more important than horsepower with a diesel.
By the way, our old dyno is for sale at work. It is an M&W P2000. I believe it will go to 400 hp. We are asking $2000 for it. It comes with 540, 1000, and big 1000 shafts.
A.P.
07-28-2004 09:43:30
 Re: Super 88 diesel on dyno in reply to Lynn, 07-25-2004 08:53:20
What head are you using on the engine? If you are smoking really hard you might want to start reducing the amount of fuel from the pump. Leave the torque screw alone, use the internal adjustment. You can over fuel the engine and loose power.
As far as energy cells go check the ones from an early 1800 or a 1650 engine. You may also want to see if the cells from a 425 ot 504 Moline will fit. I wouldn't mess with them until I was sure everything else was dialed in.
Good Luck,
A.P.
WES
07-26-2004 08:52:47
I'm interested in the Dyno. More details ?
Does it read torque? age? condition ?
Location?
Lynn
07-27-2004 05:19:00
 Re: Re: Super 88 diesel on dyno in reply to WES, 07-26-2004 08:52:47
Bought brand new in 1975. It can read torque by converting pressure on a graph. It is in average but good working condition. Electrical tach doesnt work anymore, we have been using a hand held tach. We have parts and owners manuals also. The dyno is located in McPherson, KS at the John Deere dealer. For more questions call 620-241-3553 and ask for Glenn Johnson.
Krouthead
07-25-2004 09:30:39
Be careful with those pre combustion chamber ports,you can do more harm than good.My suggestion would be to give it more air if possible before changing the ignition ports.Just a suggestion. Did you advance or retard the timing?Depending on how much fuel your getting it may need to be retarded in lieu of advanced??That pump is capable of about 175 max without internal mods.What class are you pulling this in div 3 or 4? If you class allows install water injection on your intake,nothing fancy just windshield washer pump with sprayer orfice ,1 per 2 cyl.Indirect injection works real well with a little H2O.
Oh yeah a stock 4 cyl 325 Ci deutz engine with stock stroke and pump puts out 81 hp @ 2100rpms
ive got one of these ready to pull, probably let you have it for less than your motor cost alone. Just jokin ya
Krouthead
JDGnut
07-27-2004 13:08:35
 Re: Re: Super 88 diesel on dyno in reply to Krouthead, 07-25-2004 09:30:39
The Krouthead lives!!!!!
Krout.. is that the same pump that is used on the WD45D's?? (Looks the same on the outside.) We never did get any more HP out of our little WD45D... (haven't done much to the injectors.) but have the screw about maxed out... (I guess we can shorten the rod on the inside... anyother little tricks??? ) Did you pull a WD45D a few years ago.. saw a nice one in Cleveland a few yrs ago... JDGnut
