AC stroker crank
Larry (OH)
07-23-2004 18:32:51
looking for a stroker crank for a WC/WD block. using a stock 45 crank now. Not sure how big I want or can go. Maybe 5.5"?
don
07-26-2004 17:29:08
 Re: AC stroker crank in reply to Larry (OH), 07-23-2004 18:32:51
I have a stroker crank for a wc-wd-45 for sale. Stroke is 6.375. Also have some big bore pistons for the same. 4.625.
Tom (WA)
07-27-2004 19:20:30
 Re: Re: AC stroker crank in reply to don, 07-26-2004 17:29:08
How much machine work has to be done to the block and pan for this setup? Do you have to weld the liners into the block? Is there any clearance problems in the cam area? How many hours on the crank?
Larry (OH)
07-27-2004 12:59:42
What does that crank and piston combo come up with for C. INCH????
Also how dependable is it
Tom (WA)
07-24-2004 20:01:13
I put a 5" stroker in my WD this last winter and it worked out real nice. You need to keep rod bolts as short as posible with self locking nuts (ARP work fine)to keep end from hitting pan lip at the block. Looked like 5.5" would have went in with a little pan clearenceing.
Tom (WA)
07-25-2004 21:06:59
 Re: Re: Re: AC stroker crank in reply to redcub, 07-25-2004 12:50:52
With the 5" crank I did not have to grind or notch the block or the pan. You need to keep the rod bolts as short as posible for clearance. I am running 4.125" pistons with a 60cc dish and a CR of 11.5/1 and a reground cam set up for 2000 RPM. Motor puts out around 55-60HP. Very good reliable puller in the 3500 & 4000# antique classes in our club.
jason
07-24-2004 10:16:59
Can you tell me how to build a wc for pulling?
ChadS
07-26-2004 09:23:05
 Re: Re: AC stroker crank in reply to jason, 07-24-2004 10:16:59
D-17 engine if the rules allow it is the cheapest route, but a potent combination, old gleaner combines had this engine, see an old gleaner combine, somewhere, stop n see if they would sell the motor. You can take the crank, cam, rods, from the 45-d-17 and put them in the wc block, with wc pistons makes a stroker. 1/2 inch I think,, cheap HP!! ChadS
Winner
07-26-2004 21:04:04
 Re: Re: Re: AC stroker crank in reply to ChadS, 07-26-2004 09:23:05
Sorry CS, maybe BS, but 17 and E combine cranks have to large a main journal to fit in WC crankcase. I now worry about your IHC info.
ChadS
07-27-2004 07:48:06
 Re: Re: Re: Re: AC stroker crank in reply to Winner, 07-26-2004 21:04:04
Use a WD 45 crank then
ChadS
07-27-2004 07:55:06
 Re: Re: Re: Re: Re: AC stroker crank in reply to ChadS, 07-27-2004 07:48:06
Question it all u like. A 45 crank will do the same, all I mentioned was the late model version of the engine. go harass some one else, did not see you give any valuable info in this post.
