rear suite case weights
paul
07-23-2004 13:25:09
is it better to have the weights closer to the rear wheels or in the center of the tractor.i cant see how it would make any difference.paul
ChadS
07-24-2004 07:56:16
 Re: rear suite case weights in reply to paul, 07-23-2004 13:25:09
It would make a difference in balance of the tractor. If you can make the rear heavy enough, to when you pull, the front is light, then you can move weights forward to keep it down, and not nessisarily put the weight on the front bar of the tractor. Good place for a bracket is in front of the wheels on the belly of the tractor, a weight bracket behind the seat, or behind the axle, for when you have tracks in which you cant get the front end up a bit on looser tracks. Chad
