Percentage Formula
Jerry
07-22-2004 05:55:59
We had a small tractor show pull with a lot of weight variance. I beleive that the percentage rating would be the best for us. Can anyone help with the formula that is used? Thanks
ChadS
07-22-2004 06:12:45
 Re: Percentage Formula in reply to Jerry, 07-22-2004 05:55:59
is it weight transfer,, or deadweight sled? For weight transfer,, our club used the following,,
83Xinches pulled+3260(weight of the box on the sled)Divided by tractor weight=precentage pulled
in deadweight,,, just divide the tractor weight by the sled weight=percentage pulled. Our club sled had a tape measure on the rails, that measured how far the box moved up the rails, (transfer sled) that is the distance measured, or inches pulled. the same formula works for the deadweight pulls, for thos that dont make the full pull, and percentage had to be figured, DCTOM,,, Did I leave anything out? Besides from a distance pull, it takes a bit more calculation to run up the percentage,, Yesterday, went to a pull, puller 408percent, super track it was. Hope we come back next year!!!! Hope this helps, ChadS
DCTOM
07-22-2004 08:07:52
 Re: Re: Percentage Formula in reply to ChadS, 07-22-2004 06:12:45
YES; 3260 IS NOT THE WEIGHT OF THE BOX BUT WEIGHT YOU START, IT IS THE WEIGHT OF THE PAN WITH BOX ALL THE WAY BACK DC
