head gasket on JD A
Jim V
07-18-2004 19:05:44
I am having a problem with blowing out my head gasket on my a near the spark plug. Is there an aftermarket supplier for head gaskets that will handle the higher compression. Thanks Jim
Mike in Mo
07-19-2004 06:08:17
 Re: head gasket on JD A in reply to Jim V, 07-18-2004 19:05:44
Try a Fel-Pro #7744SBX. I get mine thru an O'Reillys auto parts store, but almost any other auto parts store should be able to get one for you. I used to blow a Deere gasket about once a year, but have never blown a fel-pro. I paint with aluminum paint and put it on wet. Be sure to re-torque after reaching operating temp. Another post mentioned a Victor gasket, if they are still like the old Victors I have taken off (appeared like a copper/steel sandwich) it would probably be better than the fel-pro which is a composite and steel sandwich. Mike
al
07-18-2004 20:18:53
I got mine from napa it was a victor?? it had metal around it where the ones from Deere don't
