SAFE R.P.M.s
Phil K.
07-18-2004 12:33:29
Im trying to find out also along with my fuel question. there are some class options that there are no rpm or hp limits, what is a safe rpm for a 1945 JD GM? the work ive done to it is as follows if that helps any.
Higher CFM carb from Roberts
Hot Mag from Magneeders
Milled head 25 thousandths
Compression Ring Inserts.
Stock pistons and block.
Thanks Guys!
Smart A
07-18-2004 19:46:23
 Re: SAFE R.P.M.s in reply to Phil K., 07-18-2004 12:33:29
Should be safe up to about 1500rpms and maybe make about 50 horses
