IH truck motor?
truckin
07-17-2004 15:02:10
got an old (1951-2-3?) international steak truck, was wondering how to tell what motor is in it and what is good about it. i know its a big V8 gas....any casting numbers or stand out information about it? what about use in pullin or boltin in a tractor such as mentioned before..?
jn6047
10-15-2004 12:02:49
 Re: IH truck motor? in reply to truckin, 07-17-2004 15:02:10
I know this is an old thread, but I'm curious if anyone knows of any place to buy performance hard parts for these SV series of engines, the 392 in particular. I've got a cam, headers, distributor, but I'm looking for rockers, rods, etc. Thanks very much.
Buzzman72
07-18-2004 10:54:04
First off, International didn't make ANY V8's until 1956 for the 1957 models...and THEN those were the LV-series engines, which were HUGE. They included the V-401, which made 206 hp @ 3600 rpm and 355 lb/ft of torque @ 1800-2000 rpm, and weighed 1089 lbs with accessories; the V-461, which made 226 hp @ 3600 rpm and 420 lb/ft of torque @ 1600 rpm, and weighed 1088 lbs dressed; and the V-549, which made 257 hp @ 3400 rpm and 505 lb/ft of torque @ 2000 rpm, and weighed 1108 lbs. Later incarnations of the LV-series engines included the V-478 and the V-605, but I don't have the specs on them. The 478 and the 549 also found their way into Dodge trucks in the 1970's, and the last year for them was 1979.
The SV-series engines, which include the V-266, V-304, V-345, and V-392, didn't come along until about 1958, with the B-series trucks. So if your truck is, indeed, a '51-2-3 year model, the V8 in it has been transplanted from something else and is NOT the original engine.
Not sure how to ID the LV-series engines, but the SV engines have the engine ID stamped into a flat machined surface on the front of the engine, just below the passenger-side cylinder head...top row is engine ID, second row is engine serial number.
The V-549 is the gasoline equivalent of the DV-550 or 9-liter diesel, used in the 1468 tractors, if I'm not mistaken.
thanks for the info
07-18-2004 16:14:22
 Re: Re: IH truck motor? in reply to Buzzman72, 07-18-2004 10:54:04
i was wondering alot cause i hear about the IH trucks and scouts on here alot, and didn't know for sure what year this truck is..but i'm sure its in the 50's..i'll look and see what i can come up with...thanks alot
Buzzman72
07-18-2004 19:53:42
 Re: Re: Re: IH truck motor? in reply to thanks for the info, 07-18-2004 16:14:22
For the best info on the Scouts--and the SV-series V8's--try binderbulletin-dot-com or justinternationals-dot com...and for the OTHER Internationals, a good source of info is oldihc-dot-org ...About 2 years ago, I was searching for info on the V-549 engines...found some good info on binderbulletin, but for complete specs I ended up buying an old IH sales and engineering bulletin off eBay...that's where the HPs, torques, and weights came from.
And if we can't share the info we have, what earthly good are we? So I try to help out when I can.
Wanda Brooks
11-26-2005 20:46:36
 Re: Re: Re: Re: IH truck motor? in reply to Buzzman72, 07-18-2004 19:53:42
Just wondering where I might find a diagram of the distributer cap and wires to show me the firing order. Is there somewhere online to download such information?
Thank you
OkiePuller
07-18-2004 20:45:49
For what it is worth, the V-8 549 works great in a F-20 chassis in the semistock class.
steve c
07-18-2004 06:20:03
it is most lilky 345 international.
