rear weight brackets on farmall
sprout
07-17-2004 06:11:36
i was wanting to pull at the county fair pull this weekend with my farmall m but don't have brackets made for the back to hang the suitcase weights from. i'm not much of a fabricator but i have an uncle the could make me some brackets if i had some pics/dimensions for him to use. thanks to anyone who is willing to help me out with this situation.
Eric W
07-18-2004 18:48:50
 Re: rear weight brackets on farmall in reply to sprout, 07-17-2004 06:11:36
Just find a piece of 3.5"-4" angle iron, about .25" and drill it to bolt to the top backside of the platform. Use the 2 or 3 bolts that hold the platform down. Make it as wide as you want between the rear wheels.
Redman
07-17-2004 14:51:53
a piece of 4"X1/2" flat iron works good,angle iron also works good and then you can bolt it to the factory swinging hitch on the M.
