front weights that move
Leland
07-16-2004 20:02:27
Would this be legal. I want to build a sliding rack to put on WD were a hyd cyl would automaticly move weight forwards or back and use a level switch to control movement. I just thought it would be a great way to keep front about 4-6 in off ground. or am I dreaming
1206SWMO
07-17-2004 20:52:13
 Re: front weights that move in reply to Leland, 07-16-2004 20:02:27
Automatic DQ with all pulling groups that I know of.Weights must be non movable while pulling.
as long as
07-17-2004 11:10:32
as long as you don't extend the weights past where they need to be and the rules don't say something like "weights can not move during pull" you should be fine. if you get disqualified you're being dq'd for breaking a rule that doesn't exist.
earlschieb
07-16-2004 23:12:55
I think that you are dreaming, I tried that same idea 30 years ago, and got a big disqualified out of it, maybe it will fly now, but I doubt it. Good Luck!!!!! !!!!! !!!!!
