Mm 445
minnie mo
12-22-2001 13:23:49
I have a 445 MM. Is any one pulling one or is any one pulling with some one that is.If so how does it fair.
stan burch
12-27-2001 19:35:05
 Re: mm 445 in reply to minnie mo , 12-22-2001 13:23:49
we pull with a 445 only time we done good was at 3500 pound class on hard clay pulling a stone boat otherwise we spin out still tying to get it dialed in as there is only one tractor ever made and that is MM good luck
SLOW MO 57
12-28-2001 13:51:30
 Re: Re: mm 445 in reply to stan burch, 12-27-2001 19:35:05
HOW DID YOU GET IT IN 3500? WHAT DID YOU TAKE OFF?I PULL MINE IN 4000-7500. I CAN NOT HOOK UP BELOW 4500 BECAUSE IT'S HEAVY ON THE FRONT. I PULL DIV.2 I DO REAL WELL IN 45OO-6000 AND GOOD 6000-7500 ON A STICKY POWER TRACK. I PULL IN INDIANA & OHIO. I AM PLANNING ON TAKING IT TO COLUMBUS OHIO IN MARCH. WHERE ARE YOU OUT OF? YOUR RIGHT, M.M.'S RULE, BUT I ALSO PULL A BLACK M,A FORD 600 & A STROKED 8N FORD. THE MM IS MY FIRST CHOICE.
