Jackson,MN tractor pull
JDBert
07-12-2004 08:24:31
Tractor pull in Jackson MN, July 18th starts at noon. 3500-11500 stock 4500-7500 open.
Andy
07-13-2004 13:34:59
 Re: Jackson,MN tractor pull in reply to JDBert, 07-12-2004 08:24:31
What kind of track is it? Is there a speed limet or rpm for stock classes?
JDBert
07-14-2004 05:20:15
 Re: Re: Jackson,MN tractor pull in reply to Andy, 07-13-2004 13:34:59
Solid clay track, 40'X 350' Depending on weather we will start watering probably thursday night. Stock class is prior to or in production in 59'. Tire size limits depending on class up to 7500 then any size is ok. 3.5 mph no shifting no TA use. original rim and wheel set up (ie no pressed steel on a JD "G") No cut tires. Weight brackets are no further then 11' from center of rear axe. Engine, stock block, no blowers or turbos except factory (99 ollie, 435 JD). Stock heads manifold and carbs, air cleaners can be modded. 10% over stock RPM's. 20" high hitch not less then 24" from center of rear axe for a 3" clevis, loops are 27" from center of rear axe. PTO must be operational.
Andy
07-14-2004 07:42:57
 Re: Re: Re: Jackson,MN tractor pull in reply to JDBert, 07-14-2004 05:20:15
Can a standard tread with no pto be pulled?
JDBert
07-15-2004 12:10:23
 Re: Re: Re: Re: Jackson,MN tractor pull in reply to Andy, 07-14-2004 07:42:57
Yep thats ok
wags
07-12-2004 09:50:29
What rules in open classes?
JDBert
07-14-2004 05:23:31
 Re: Re: Jackson,MN tractor pull in reply to wags, 07-12-2004 09:50:29
hitch is 20" high no less then 18" from center of rear axe. No radials, cuts are OK. Naturally aspirated, no alcohol or nitro. 11' from center of rear axe for front bracket. Max speed of 10MPH past 75 feet. Wheelie bars are required as well as kill switches. 20% over on RPM's.
