Super C Engine
Marv Tobey
12-20-2001 19:22:36
I have heard that if you put a combine engine in a SuperC you get more HP. What model combine has this engine? How much hp do you gain? What size cid is the combine engine Thanks Marv
jim
12-24-2001 14:56:44
 Re: Super C Engine in reply to Marv Tobey, 12-20-2001 19:22:36
their is one for sale on e-bay, a C135 power unit
Dave H
12-22-2001 06:17:13
C153 is correct.I believe it is the same motor used in a Farmall 504,has about 40 hp.I have one that came out of a hay swather and have put it in my Farmall BN.That is one hot little red tractor,I`ll tell you what.It did bolt right up to the bell housing,but I had to grind on the front casting to clear the steering shaft,and the water pump presented minor fit problems.I pulled it a few times in the 2500# class and it blew every everyone away,now is banned in three states! Good Luck
r g
12-22-2001 10:10:28
 Re: Re: Super C Engine in reply to Dave H, 12-22-2001 06:17:13
i like that story, the 153 was bit higher in the horses if i remember. i grab all the power units i can off old junk combines. ron
r g
12-22-2001 05:25:13
c153, for what i read it does not bolt right up, starter, etc need some tlc. combine motors, got one here on the log splitter, now no one barrows it hehe
ron
