REMUS, MI. TRACTOR PULL FUN FUN.
OLIVER AND M PU
07-11-2004 05:44:51
JULY 16,17, 18 WE ARE BACK AT IT AGAIN FOR A TRANSFER SLED PULL ON FRIDAY NIGHT WITH STARTING AT 4:00 P.M. WITH 15 CLASSES. 3,4,5,6,7,8000#. THESE WILL BE RAN AT BOTH 3.5 M.P.H. TOP CUTS AND 5.0 M.P.H. FULL CUTS AND UP TO 18.4 38 TIRE SIZE FOR THE 5.0 M.P.H. AND OPEN CLASSES. THE 3.5 M.P.H. CLASS YOU ARE ONLY ALLOWED 15.5 TIRES. THE OPEN CLASSES ARE 4500, 5500, 6500# WITH NO TIRE RESTRICTIONS ON THE LUG AND YOU MUST HAVE WHEELY BARS AND A KILL SWITCH. ANY QUESTIONS GIVE ME A E-MAIL. SAT. IS THE DEAD BOAT THE CLASSES ARE 2750, 3500,4500,5500,6500,7500. WITH A TIRE SIZE OF 15.5 38 WITH TOP CUTS ONLY. STARTING AT 11:00 A.M. SUN. 40 AND OLDER DEAD BOAT 2750,3500,4700,6000 CLASSES.
V-8 PULLER
07-15-2004 02:24:29
 Re: REMUS, MI. TRACTOR PULL FUN FUN. in reply to OLIVER AND M PULLERS, 07-11-2004 05:44:51
Do you have a 5500# v-8 class?
Hot Rod
07-12-2004 19:45:50
Do you have any rules for this pull at Remus?
Cut tires? Drawbar height? Are wheelie bars required? Need this information to correctly set up tractor for your pull.
Thank You,
LP HEAD
07-13-2004 11:59:49
 Re: Re: REMUS, MI. TRACTOR PULL FUN FUN. in reply to Hot Rod , 07-12-2004 19:45:50
HOT ROD YOU MUST PULL FARMALLS
Hot Rod jlorinc@peoplepc.
07-13-2004 15:43:32
 Re: Re: Re: REMUS, MI. TRACTOR PULL FUN FUN. in reply to LP HEAD, 07-13-2004 11:59:49
Farmalls as well as Ford and J. D.
oliver and farmall
07-14-2004 06:02:54
 Re: Re: Re: Re: REMUS, MI. TRACTOR PULL FUN F in reply to Hot Rod jlorinc@peoplepc., 07-13-2004 15:43:32
for the 3.5 mile class you can have wheelie bars but you dont have to and you can have top cut tires only and all classes are 20 inch drawbar. the 5 mile an hour class and open classes you can bring any tire up to 18-4-38 with any style of cut with wheelie bars highly recommended for the 5 and a must for the open. the 3.5 you can only have a 15.5 max. tire size. hope i could help feel free with any more questions.
Florian
07-11-2004 18:27:26
What are the drawbar specs. Is this a money or trophy pull. What time is weigh-in? Whose sled will you be using.
Thanks
Florian
Puller
07-14-2004 01:28:55
 Re: Re: REMUS, MI. TRACTOR PULL FUN FUN. in reply to Florian, 07-11-2004 18:27:26
To get rulls call 1 989 561 2290
