Qs Chads
mike
07-10-2004 15:31:43
Chad i had talked too you about taking the spring off my 880 and using mech. wire too make it stiffer, for somemore RPM's..will it work great, my Qs is my motor work is as followed( I offset the crank, 3 7/8 bore, lots of head work(big valves 1650 inman 1650 exman, with denny mod carb) cam, fuel, pump, MSD...anyways, the motor builder set it up for 20% over Rpm,whick was like 2200 2300, now with this spring change its like 2700 its sound 100% differnt is this ok,,thanks mike
ChadS
07-10-2004 21:09:45
 Re: Qs Chads in reply to mike, 07-10-2004 15:31:43
If you were running 2200-2300 with no trouble, 2700 should be ok in my opinion, just depends on if you are allowed to run that fast of rpm. If it is too high, give back a few wraps of the spring in which you tied off with wire, should not take more than 2-4 wraps of spring wire less to lower it a few 100 rpm. I am not in love with high rpm, non oil pressure fed cranks, the 88s dont like to run high rpm with out oil pressure in the rod bearings. Unless you have a crank that is set up for it, or the 880 has that upgrade. Bottom line, if the 2700 rpm scares you, back it off to 2500 max, should be just fine. Just my opinion, Chad
