Any Way To Posi Track a Farmall M?
terry46M
07-10-2004 11:08:27
I was wondering if there was anyway to put posi track on a Farmall M ? At the local antique pulls there seems to be some tractors that their wheels spin out at exactly the sametime. These are tractors that never use to do that and we could beat easy now it is neck and neck. With our M it always has one wheel spin out before the other. I was wondering if they found something that does this. A limited slip or one they can put in and out of posi. I have heard rumors of a kit but have not been able to find one you could get. Any advive would be appericated.
Thanks
Terry
ChadS
07-10-2004 21:04:00
 Re: Any Way To Posi Track a Farmall M? in reply to terry46M, 07-10-2004 11:08:27
We have those "rumored Kits" to fit a fully adjustable limited slip/posi differential for your M. It installs easily, and adjustments can be made in seconds to the unit. email us for more info if you choose, [email protected] We can handle the biggest M engine outhere, and still keep both tires spinning!! ChadS
sowbelly
07-11-2004 14:55:34
 Re: Re: Any Way To Posi Track a Farmall M? in reply to ChadS, 07-10-2004 21:04:00
chad call me i want one.309-337-2860
FB
07-12-2004 07:59:26
 Re: Re: Re: Any Way To Posi Track a Farmall M? in reply to sowbelly, 07-11-2004 14:55:34
do you pull a W-9 farmall called sowbelly?
what about a JD
07-11-2004 11:05:49
waht about a JD or a MM? how do they work?
ChadS
07-12-2004 08:07:34
 Re: Re: Re: Any Way To Posi Track a Farmall M? in reply to what about a JD, 07-11-2004 11:05:49
I am looking into the JD differentials, have got lots of interest for them, but I have not built one yet,, We can build them for IH,OL,MH,MM,AC, Band brake models, and all IH, and OLivers, for disk brake models, we do this a bit different than the disks behind the spiders, on a puller, it needs to be a bit more precise, and forgiving to work well. 574-893-7437, or [email protected]
Sorry for the AD plug, just givin ya all some ideas on what we have these kits for. turn around is about 2-5 days for the band brake models, like H and M etc,, 7-10 days turn around on disk brake models depending on make and model,, some you have to fit precisely, and beef them up,, I can hold 800 hp with the so far, V8 mods as well with tractor rear ends in them. ChadS
