Cockshutt 40 puller
joe
07-09-2004 10:52:28
Need some opinions, building a gas 40 with the 230, machine shop said for reliabilty 320 ci is about it, 4.25 stroke and 4" bore. Looking to run
high rpms, 4-5,000. has anyone built one futher and how reliable at hi rpms what combo works best?
T-Rex
07-09-2004 10:55:44
 Re: Cockshutt 40 puller in reply to joe, 07-09-2004 10:52:28
Use a 262 from a D-19, works well. You can use a 273 from a 50, but there is tell tale signs when you do this. Chad
Shutt30
07-09-2004 13:53:25
 Re: Re: Cockshutt 40 puller in reply to T-Rex, 07-09-2004 10:55:44
What tell tail signs other than the engine tag?
Ironman
07-11-2004 10:44:45
 Re: Re: Re: Cockshutt 40 puller in reply to Shutt30, 07-09-2004 13:53:25
It is even more obvious when you swap to the 262 motor than the 273 motor. After being built the 40 motor and the 262 are going to be pretty much equal. The 262 just gives you more to start with (72 hp vs. 40).
