Qs 4 chads
mike
07-08-2004 09:34:32
i want about 500 more rpm, out of my 880, If i take the spring off, compress it and use some mech. wire too hold two for the coil wire lope together, will that make my spring harded and make more Rs??? thanks...
ChadS
07-08-2004 09:45:06
 Re: Qs 4 chads in reply to mike, 07-08-2004 09:34:32
Any time you can increase the spring tension, you will gain rpm. I have seen pullers put garbage bag ties around a section of the spring, to gain a few rpm, over time, that spring gets weak again and stretches out. It would work for a season I would say, You may possibly use a spring off of a differnt model of oliver, that had a higher rpm setting, that uses the same style of set up the 880 uses. But, yep, your idea will work! Hope this helped, Chad
