JD A galoping
galoping tracto
07-03-2004 21:26:08
I got a JD A that jsut galops to beat the ban and in can't for the life of me figure out why. What possibly can casue this? and corrections. it only galops when it is under a light load. thanks alot anyone.
buickanddeere
07-04-2004 11:43:35
 Re: JD A galoping in reply to galoping tractor needs fi, 07-03-2004 21:26:08
At idle and light load a plugged idle fuel passage will do it. Too much gain on the governor linkage/spring will do it too.
johndeere_john
07-04-2004 07:35:33
Sounds like the governor if the linkege is free. Jon
what oculd it be?
07-04-2004 07:44:42
 Re: Re: JD A galoping in reply to johndeere_john, 07-04-2004 07:35:33
what could it be in the govenor..it was all rebuilt with all new berrins and bushings and the C deally that runs the throttle off teh weights. the weights look like new. im baffled....:S..thanks for the help
BUDD
07-04-2004 06:10:22
Make sure all you linkage to the carb is adjusted properly and free moving.
BUDD
we tryed...
07-04-2004 07:39:35
 Re: Re: JD A galoping in reply to BUDD, 07-04-2004 06:10:22
we tried a few places on the linkage on where it should be. can you tell me how they should be or how to adjust them properly. we pulled it tight to the gov. weights and then tightedn down the rod goin to the carb. thanks alot for the help
BUDD
07-04-2004 16:31:37
 Re: Re: Re: JD A galoping in reply to we tryed..., 07-04-2004 07:39:35
If I remember right, with the motor off and throtal wide open the linkage should be a half hole short at the carb.
BUDD
