Spark plug heat range
Dave S
07-03-2004 16:07:15
I just got my antique puller home and have a question about the plugs. This is a 13.5 to 1 comp engine and the builder said to run a cooler plug to keep from making a hot spot and possibley burning a hole in the piston. Theres not alot of choices of 18mm plugs out there as you know. Stock heat range in autolite is 386, the only cooler plug by autolite is the 373. I'm dynoing this motor so it will be running longer than usual. Has anyone run this plug? What about using adapters and a smaller thread plug? Dave S
BUDD
07-04-2004 06:13:45
 Re: Spark plug heat range in reply to Dave S, 07-03-2004 16:07:15
I "think" Champions have colder heat ranges!
BUDD
