weight dist.
Spuds
07-03-2004 06:51:52
Just started pulling, Been spanked real good! Question I have is if you can put 450 pounds on your tractor to max your weight class where do you put it? I found out it's not the rear tires unless you like your front tires 3 feet in the air, do you put it all on the front end or some where in the middle of the tractor. One club I pull with doesn't allow suitcase weights so then what do you do? I hope you all don't thinkI'm dumb I'm just new to this.
Thanks Spuds
Mopower
07-04-2004 10:22:57
 Re: weight dist. in reply to Spuds, 07-03-2004 06:51:52
Spuds, I got a theory on that kind of thing, but may take some explaining. Seems to work on our U and UB. By the way, I know how to keep your drawbar straight.
264ss
07-03-2004 10:05:20
load your front tires, shorten your hitch about 2 in,make sure your radiator is full,and if all else fails buy some front wheel weights $$$
