M-Carb
Justin
07-01-2004 19:29:09
Looking for a larger carb to put on a M. Is there anything bigger I can start with that uses the same governer controls? Thanks
ChadS
07-02-2004 08:06:56
 Re: M-Carb in reply to Justin, 07-01-2004 19:29:09
Why cant you use the carb you have? change the venturi size. How many rpms are you running, cubic inch, and how much compression does you M have? On the load adjustment screw, can you back it out when the engine is at full throttle, and make it run rich??? ChadS
Ohio M Puller
07-02-2004 04:13:57
Call Gary Baker in Michigan with your cubic inch and your pulling RPM's, he can set you right up. 734 678 9688
Ohio M Puller
randy hall
07-01-2004 20:40:26
w-9
