grinding a stock allis cam wd45
larry
06-25-2004 23:36:58
does any one know J. T. Richardson,s phone# or email i was told he will grind my cam if i can find him
Ron
06-26-2004 10:38:13
 Re: grinding a stock allis cam wd45 in reply to larry, 06-25-2004 23:36:58
if you are going after more power, a proper cam re-gring is good, but you will be well served if you go ahead and have a COMPLETE Custom Valve job done.. Have the valves ( especially the intakes) re-shaped and Polished.. Have the port throats radiused with at least a 3 angle cut under the seat, with one above the seat. I use at least 4 angles on my valves, then polish them till they are a smooth continuous radius...THEN cut ONLY the seat width on the valve. The seat reflects the same seat location, with everything else being a transition to and from the valve... This, coupled with the cam will double the effectiveness , and get you a huge increase in cfm airflow.. Airflow is hugely increased over the entire valve lift, with the re-shaped valves. Originally, flow is measured at lifts starting at .050" lift.. I do this myself, but you can get it done--it aint cheap, but it is where the Power is...!!!
reddog
06-26-2004 06:08:07
Tommys # 336-584-8254
