JD 70 Gas
Oppy
06-24-2004 07:46:59
I'm considering doing some head work on the 70 gas. I've got some good advise as to installing 70 all fuel valves in the gas head, among other tips. Does anyone know dimensionally the difference in these two types of valves. I'm thinking that the all fuel valves are longer. If so, how do I get around this?
JDGnut
06-24-2004 20:42:02
 Re: JD 70 Gas in reply to Oppy, 06-24-2004 07:46:59
If they are just longer, you will have to have a grove cut in the stem for the keepers, and just cut the stem off to get the correct height.. I think the Allfuel valves are going to be closer to a G valve.. JDGnut
Oppy
06-25-2004 07:43:19
 Re: Re: JD 70 Gas in reply to JDGnut, 06-24-2004 20:42:02
JDGnut,
To your knowledge, is the All fuel valve's stem material one that can be machined and still withstand the stress of operation? Where I'm coming from is that some vales have a harder material at the end in order to support the grove. Other valves have the same material throughout. I don't want to cut-back the all fuel valve and get into softer material and then drop the valve during a pull because the grove is in softer material.
Thanks for your help!
