Lightweights - Best 2500#-3000#
Mopower
06-24-2004 05:19:33
Ok guys...one more time. What are opinions on the best lightweights around 1950? 2500-3000# Any other brands?
Allis Chalmers B or C
Farmall BN/C/A
Moline R or BF
B.F. Avery
General
Oliver 60
Case VAC
Deere H
Cockshutt 20
dan
06-24-2004 20:37:09
 Re: Lightweights - Best 2500#-3000# in reply to Mopower, 06-24-2004 05:19:33
why not an oliver 66? i have 2 of them down to 2750. they are real competitive from there to 3500. we have 3.5 mph speed limit, 35 hp for 2750&3000. 40hp for 3500.
marlowe
06-24-2004 18:37:31
and i should have said UNDER 3000 over that the ihc super c is a winner
marlowe
06-24-2004 18:33:40
YOU MISSED THE BEST ONE FERGUSON TO-20 with a sherman trans will out pull any you posted and i got 26 1st. place wins to prove it. they are about 28 hp.
Pete
06-24-2004 17:37:27
mopower its time to quit talking and start pullin, get one of those molines out and get it down to the track, if you spent as much time working on them as you do talkin about them you would have all of them pullin. see ya soon Pete In Marquette
Mopower
06-25-2004 04:30:42
 Re: Re: Lightweights - Best 2500#-3000# in reply to Pete, 06-24-2004 17:37:27
I'll be there Sunday with one of them! Not sure which. The GBD is running again but no 7500# at Fowler. Findin' the time my friend. Heard Mark whooped your butt.....
Augie
06-24-2004 11:46:02
We've got a VAC Case and a C Farmall running DivII type rules. I've also pulled a buddy's BF Moline.
Of those 3 the Case is balanced better below 3250lbs.
acorange
06-24-2004 08:42:21
A "wartime" WC with a pressed steel rearend is
easy to get under 3000lbs. They are very good and
easy to increase the H.P. on.
Locally there is a super C IH that kicks #$% all the way to 4000lbs.
My 2 cents.....
CASEPOWER
06-24-2004 08:51:14
 Re: Re: Lightweights - Best 2500#-3000# in reply to acorange, 06-24-2004 08:42:21
Was told by a man that bought a steel WC rear and weighed it against the cast, that it was accually heavier. Everyone else tells me there lighter. Have you ever weighed one??
slowsmoke
06-26-2004 05:32:34
 Re: Re: Re: Lightweights - Best 2500#-3000# in reply to CASEPOWER, 06-24-2004 08:51:14
I have a wc with cast rear end, pulls 3000 class with cast wheels.
CASEPOWER
06-24-2004 08:22:16
I put 40 feet on a WD-45 last sat. after he powered out in 3500. He was running 2nd or 3rd gear in unlimited speed super class, I was running in 2nd gear with my VAI case. The closest thing behind me was a ford and he was 11 feet back and he spun out. The fords are very tough in the lighter classes. The fords are taking over were the WC and WD used to dominate.
redhot
06-24-2004 13:55:42
 Re: Re: Lightweights - Best 2500#-3000# in reply to CASEPOWER, 06-24-2004 08:22:16
What about a 3500 lb Farmall 460
CASEPOWER
06-24-2004 17:43:34
 Re: Re: Re: Lightweights - Best 2500#-3000# in reply to redhot, 06-24-2004 13:55:42
As long as they let it in the class. Rules are weird around here.
geb
06-24-2004 09:43:53
Come on CP, the Fords are getting better but I don't think they have caught a good hot AC yet. Yes they do win some times but that is because they are working harder but are not beating the AC's on a regular basis. The Fords are at a disadvantage because the aren't able to get the CID that the AC does.
CASEPOWER
06-24-2004 13:11:39
 Re: Re: Re: Lightweights - Best 2500#-3000# in reply to geb, 06-24-2004 09:43:53
Geb, the Fords are not coming on as quick at CATPA and DATPA as they are at others, like OTTPA. Give it time though. The Ford is a later design engine that runs more efficient then the WC, the stock rpm's is higher, and the transmissions are fast. I know the OTTPA sled does not take as much power to pull, and works more with spinning a tractor out, but there are 15 or 20 Fords at each pull. Give it a few more years and there will be allot of Fords winning. Don't get me wrong, I don't like them, and I would build a Fordson before I built a Ford, but there coming.
GEB
06-24-2004 13:25:44
 Re: Re: Re: Re: Lightweights - Best 2500#-3000# in reply to CASEPOWER, 06-24-2004 13:11:39
Yes I'm aware of the Fords at OTTPA but they aren't going to be as competive simply because of CID. I will agree given the same CID the Ford would have the advantage due to the RPMs. The Fords also have a gear problem unless they have spent some money on horsepower, the 5 speed is too slow and the 4 speed is too fast for most tracks. Again there are some Fords that do quite well. I'm certainly not anti Ford because that is what I grew up farming with and that is what is still used on our farms. When looking to get back into pulling (antique pulling) I looked at building a Ford but decided to go with the AC because I felt they had more potential.
Chads
06-24-2004 08:17:36
I think that a C Farmall would be good in those classes, But those WC AC are hard to beat there too. Next choice would be a VAC Case,, Like Casepowers tractor,, LOL Would love to go see that one pull some time. Chad
DCTOM
06-24-2004 12:54:34
 Re: Re: Lightweights - Best 2500#-3000# in reply to Chads, 06-24-2004 08:17:36
CHADS; MAYBE SOMEDAY YOU WILL SEE ONE PULL, THE ONE I HAD IS NOT FAR FROM HERE BUT NOT LEGAL UNLESS HE WANTS TO COME PULL EXIBITION OR CHEATER LOL TOM
06-24-2004 10:33:56
isn't their a combine motor that will fit in a farmall C that is susposed to be around 45 hp?
ChadS
06-24-2004 10:43:31
 Re: Re: Re: Lightweights - Best 2500#-3000# in reply to ?, 06-24-2004 10:33:56
Yes, the C-152 will bolt it,, there is a few things to do to fit it in the chassis, mostly putting in a pilot bearing on the crank, I built one for a neighbor like that, made 52 HP. Fun tractor,, alot of power for it too. The engines are in a 92, 102,203 IH combines I belive. from what I understand, they would go into the B too!! May be wrong bout that, but have heard it may. Also the radiator top hose has to be redone I used the C radiator, and welded a cast tube into it so the hose fits on it. Chads
Scott
06-24-2004 08:00:06
Stongest 3000# tractor I've seen is a AC WC, or Farmall H. They'll get to 3000, but you have to work at it.
Mopower
06-24-2004 10:14:39
 Re: Re: Lightweights - Best 2500#-3000# in reply to Scott, 06-24-2004 08:00:06
I know a WC and H are tough and can go real light, but I would not exactly classify them with a little Allis B, JD H, or Farmall BN in 2500. Even am MM R could arguably be a heavy machine compared to these tiny tots.
Charles Poosch
06-24-2004 06:23:51
There's a Ferguson TO-30 that runs with us in Div. 1 & 2 on occasion that's a good horse. He can weight up on occasion and whip some guys at 3500+...
CP
Mopower
06-24-2004 07:00:18
 Re: Re: Lightweights - Best 2500#-3000# in reply to Charles Poosch, 06-24-2004 06:23:51
Almost forgot...Massey 22? Yeah I've seen some strong Fergusons.
