CO-OP TIRES
LOW BUDGET M
06-21-2004 19:05:01
ANYBODY EVEN RUN 15.5X38 CO-OPS. I HAVE A "M" WITH 75 HP, RUN UN-CUT TIRE CLASSES 3-4 MPH. THINKING OF BUYING THESE TIRES FROM LOCAL FARMER. 40 % TREAD. APPRECIATE ANY HELP WITH MY DECISION.
Ollie Puller 2
06-24-2004 19:09:00
 Re: CO-OP TIRES in reply to LOW BUDGET M, 06-21-2004 19:05:01
I have an Oliver 88 that I pull farm stock from 5000--7000 lbs. The CO-OP tires work fine. Mine are old and hard.Good Luck
Mike Aylward
06-23-2004 19:55:51
Low Budget, the Co-op tires have a tread design very similar to a BFG tire. They are much lighter, though. They are one of the lightest tires for their size that is out there. They have a very thin sidewall and carcass and are less forgiving of the wrong air pressure but when they are "right" they work very well. If you don't use them somebody will want them. Mike
BUD BARENIE
06-22-2004 03:59:48
I PULL A PAIR OF CO-OP AGRI-POWERS. DIVISION 1
FIRST GEAR 5500-7000LB 15.5-38'S ON 14" RIMS ON A
SUPER-M. TRACTOR WAS ABOUT 62-65HP MOTOR IS APART RITE NOW. WENT TO 5.75 STROKE !!!
I HAVE THE HUBS TURNED IN AND THE RIMS PUSHED AS CLOSE TO THE TRACTOR AS I CAN. RUNNING 14.5 POUNDS OF AIR. HEAVY CLAY IN OUR AREA. THE GOOD NEWS IS (FIRST) THESE ARE NON-CUT, NO CHEATER CUT,
JUST GOOD ROAD WEAR. 75HP MIGHT NOT BE ENOUGH JUICE TO PULL THEM HEAVY. PICK A LINE LOAD UP THE MOTOR AND LET THEM GET BUSY !! I WOULDN'T SELL THESE THINGS FOR 5GRAND !!! JUST MY OPINION, BUT I KNOW 9-10 TIMES I'LL BE HOOKED UP !!~! DO YOU OWN THEM YET !!
HAVE FUN
BUD BARENIE
A puller
06-21-2004 20:57:53
got a set of 16.9x38's road worn and a set of 15.5x38 top cuts and a set of 16.9x38 firestone f151 F&Rds and both 16's pull good...the firestones are spun backwards. these tires have won numerous pulls, but have had them longer then the 16 coops. the 16 coops have never placed lower then 5th in classes between 15 and 55 tractors. haven't pulled the 15's yet..but assume they will be good too like the other coops. most people still perfer the firstone reguardless.
ol George
06-21-2004 20:23:08
I would get them, they are very similar to a Firestone field and road.
