More air flow in Super 88
Jon
06-21-2004 09:44:57
What steps should be taken to get more air into my Super 88 Diesel. It has a 4x4 motor with a stock head. The injectors and pump has been tuned to flow more fuel but smokes under load. I would like to get rid of some of the smoke by flowing more air. I want to do anything I can to get some more air. Most have told me to turbo it but thats limits so many places where you can pull. Any advice would be great!
Dano
06-23-2004 21:58:19
 Re: More air flow in Super 88 in reply to Jon, 06-21-2004 09:44:57
Look at having the head opened up,bigger S.S.valves that are necked down and porting,also the intake could be polished by having a grit compound flowed thru it.It isn't cheap but can help alot.Cam would help also.
A.P.
06-21-2004 19:05:11
Take the preheater element out of the intake manifold. Get rid of the oil bath aircleaner and go to a good flowing paper element. Have the head flowed/ported and the manifolds matched to the ports. What are you using for a cam? Change to higher ratio aluminum rockers. Long shot - Use dry ice for an intercooler; cooler air is denser air even if it isn't compressed first. Some black smoke is okay - too much and you are losing power. Where are you really at now?
A.P.
Jon
06-22-2004 05:57:11
 Re: Re: More air flow in Super 88 in reply to A.P., 06-21-2004 19:05:11
For an intake I have a straight pipe off the intake with a KnN Filter. The motor is 4 stroke and 4 bore but the head, cam, and everything(internal)is stock. We have the pump right where it needs to be. We are getting the max hp where it is set. See the pump I have is capeable of alot more fuel but the engine doesnt need it withouth the air.
