intake on ih 301 engine
wags
06-21-2004 05:43:30
Anyone know the largest stock appearing intake I could put on my 560 gas with 301 ci setup and where I could find one?
ChadS
06-21-2004 06:54:20
 Re: intake on ih 301 engine in reply to wags, 06-21-2004 05:43:30
LP engines from the combines had a bit larger intake manifold,, The newer the engine,, you will find larger manifolds. Depending on what the rules are for your club,, there is a 2 bbl downdraft for the IH 6 cyls,, Hope this helps,, ChadS
Cody
06-21-2004 18:49:27
 Re: Re: intake on ih 301 engine in reply to ChadS, 06-21-2004 06:54:20
A Johnson intake for a 301 is huge.
wags
06-22-2004 05:47:48
 Re: Re: Re: intake on ih 301 engine in reply to Cody, 06-21-2004 18:49:27
Does it bolt right up and where can I find one, what engines did these come off of?
Cody
06-22-2004 21:42:56
 Re: Re: Re: Re: intake on ih 301 engine in reply to wags, 06-22-2004 05:47:48
The johnson manifolds were an aftermarket manifold made for 301 pulling engines. They are hard to find, but someone might on here might be able to help you. It will make a huge difference.
