264 SM Rod Length
smta puller
06-17-2004 12:34:38
haveing pinston made, Need Rod length #45750-DA ROD for a 264 SM block THANKS .
BUD BARENIE
06-20-2004 03:13:45
 Re: 264 SM Rod Length in reply to smta puller, 06-17-2004 12:34:38
HAVING PISTONS MADE UP ALSO !!!
HAD T SPEED 200.00 ON A VANIERR (SPELLING)CALIPER, TO GET THE RITE LENGTHS !!
264 BLOCK ALSO !! BLOCK HEIGTH 15.750
ROD LENGTH 10.002 ARIAS TOOK THE .002 OFF !!!
MY RODS ARE AT THE MACHINE SHOP. IS THAT THE BIG PIN ROD !!!
I WENT WITH A SMALL MOTOR 4.130 X 5.75. MY FIRST BUILD. PISTONS COME IN JUNE-26, MY WEDDING ANNIVERSARY !!! NEVER THOUGHT 23 YEARS AGO I COULD BE INVOLVED IN SUCH A COOL SPORT !!!
ENJOY YPUR BUILD UP !! GOOD LUCK !!!
Mark
06-19-2004 17:58:35
Block height,or deck height as it is called,is 15.75"If your building a stroker and don't now your deck height,just subtract half the added stroke from the compression height of the stock piston spec. and this you can tell to your piston maker.
Sweeper
06-17-2004 18:12:40
Center to center is 10 inches.
smta puller
06-17-2004 21:49:06
 Re: Re: 264 SM Rod Length in reply to Sweeper, 06-17-2004 18:12:40
THANKS FOR THE INFO NOW THE PINSTON PEOPLE NEED BLOCK HEIGHT.
bud barenie
06-28-2004 03:11:46
 Re: Re: Re: 264 SM Rod Length in reply to smta puller, 06-17-2004 21:49:06
who in the heck is making your pistons!!!
is it arais. they made mine!! the guy on the phone gave me the runn around for 3 dam weeks with needing dimensions. is it tom young !!!
after all that time i asked for his boss!!! ended up with a gentlemen named roger !!!
took 15 minutes and i had a quote faxed to me!!
15minutes instead of three weeks !!!
Sweeper
06-18-2004 19:26:25
Don't know. Measure from the place where the main bearing cap bolts on to the top of the block.
Eddie Haskell
06-18-2004 05:06:05
Where the hell do you learn how to spell! At Ole Miss?
