R puller
Mike w J
06-16-2004 10:01:07
How will a stock R do pulling ? Do I need front weights? How do you mount them? Will it pull good against a stock 4010? THANKS
Mike w J
06-16-2004 19:28:08
 Re: R puller in reply to Mike w J, 06-16-2004 10:01:07
18/4 /34 tires traction field and road new . tractor runs real good what can a guy have for drawbar hight with stock front tires its 18in. with 650/16 tires its 22in THANKS
Russell
06-16-2004 16:50:33
Hello
A stock R will pull good, as long as you get the traction. Larger tires is a good idea. if your engine is in good condition, there should be no lack of power. without weights, a R will get into the 10,000 pound class.
If you are going into the 12,000lb. class, weight the front end good as it will go up high.
we also pull a Model 80, it has wheel 6 wheel weights, and it still lacks traction so bad we have to idle it down all the way to keep it from digging holes. The front end lifts about 2 feet off the ground without weights.
Good luck,
Russell
720Deere
06-16-2004 11:31:14
I have seen some Rs pull pretty well. In stock trim they lack the horsepower, but that can be remedied. There are several ways to mount weights on the front, but I doubt that you will need them if you use a short drawbar. We pull an 80 and even in 12000 lb class with a long drawbar, it is hard to pull the front wheels up. These tractors are balanced pretty good for that.
As far as pulling against a 4010/4020, you should fare pretty well against them in lighter classes but not too well in the heavier classes.
