Oil Galleys in Farmall engine
Nate
06-15-2004 20:10:03
Does anyone have a picture or some thoughts to share about cutting into the oil galleys when stroking a Farmall H? I am going to start surgery on my block tommorrow and would appreciate any input. Thanks.
FARMALL
06-16-2004 05:32:54
 Re: Oil Galleys in Farmall engine in reply to Nate, 06-15-2004 20:10:03
On bigger strokes I cut the area in question on the oil galley right out (I use a Metabo). Then I take four pieces of 1/2" x .035 wall steel hydraulic tubing. I then expand each end (about a 1/4" L) so the tubing fits tight. Then I drive the tubes in place. Wonce in place I then spot weld them (wire feed). My motors run 75+ oil pressure.
Note: Unless you are running over 6" stroke you should not have to dent in this tubing. Take the clearence off the rods. Hope this helps Farmall
j
06-15-2004 20:28:18
I have never done it but from what I have heard, they cut to clear the rods and such and then run the oil lines outside the block or they slip a copper tube in and dent them in to make the clearance and jb weld them in to seal it. I personally would brase it or solder it but I was told JB weld....hope this helps until someone else posts. I guess the motor build would tell alot on how to go about it.
