ChadS
06-22-2004 07:58:47
Re: Re: Re: Re: Re: Qs for Chads in reply to redcub, 06-19-2004 16:44:11
They are located under the plate where the points are, 3 little screws, and the plate comes out. yes comaptible with electrinic ign. when you remove the plate, you will see 2 weights, and 2 springs, remove the 2 springs, and get a chevy recurve kit for a HEI distirbutor,, NAPA, Autozone has them. use the lightes, to the second lightest spring in the kit. Now what this does,, it speeds up the response time for timing advance. not the number of degrees of timing, just in the time it takes to respond. this affects throttle reponce, because it is an engine control. In stock form, the stock springs,, dont do hardly anything,, they are so heavy, that it would take 7000 rpm just to make em move!! this is important if you want more throttle response, it is a night and day difference. the faster the engine controls can respond to rpm changes,, the better the engine will perform. ChadS
